did you try all these
ebay
Or
Cloud rays site was a bit confusing if the connector was avial separate, you might call them.
ebay
Or
yeah, thanks guys, these all are from US based sellers. I live in Ireland. If the local electrical wholesalers havenāt got it tomorrow then Iāll order from eBay (probably comes form China or Taiwan)
Cloudray says they are global?
My cloudray shipments from China have arrived on the East coast of the US about as fast as my lightobject shipments from Californiaā¦
OK guys, update. The tube came today. So I spliced the wire from the power source to the pigtail on the tube, covered in electrical tape and silicon and then surrounded for about 2-3" each side with a silicone tube and sealed the tube at either end. I had a little difficulty getting the water tubes back onto the tube. I used a pair of small pliers into the tube to stretch it a little and then slid it on before it retook itās shape again!! The other wire I just spliced and sealed with insulation/electrical tape. I attached the brackets back on and then run the water through for about an hour to get rid of the air bubbles. I tried a couple of test presses at 10% on cardboard of the laser fired up. I still am assuming that I will need to realign the mirrors to get the best results. I tried a test engraving on slate and it seems the right side of the bed is a lighter āshadeā than the left.
You should definitely re-align after replacing the tube.
Glad to hear that it is functional!
Functional so far The alignment was a pain the first time I did it
But I didnāt think Iād get this far. The HV splicing is def patchwork but Iām not looking marks for presentation!!
I have ordered the HV connector from China for either this one or my next to be ready!!
Iām looking for the best link now for mirror alignment. From memory - make sure the beam from the laser hits mirror 1 in the middle. Then adjust mirror 2 until the beam hits the centre at various locations. Then the same with mirror 3?
Hereās a video that has been shared a few times for this:
Two guides in PDF form:
Another Update - I have completed the mirror alignment and then tried to run off a couple of engraved slates. Initial observation was that the required power to get the right result now needs to be significantly higher. Before hand for the below type of slate, I had the power (I have a % meter) at around 13%-17%. The below ones were at around 30-40%%. The 2nd pic seems better quality but the slate was a little thinner and I increased the power. On both slates the result seems to fade toward the bottom when previously I was getting excellent results. HELP?
IMG_2671|375x500
The fact that it fades as is goes down is usually indicative of an alignment issue.
Thatās what I thought. The beam seems to hit the middle of mirror 1 and then also in both locations (close and far) in the middle of mirror 2. Likewise for 3 but I need to check again I suppose.
Beforehand it was a ālittleā lower on the entry to mirror 3 but the results were fine.
Now,in saying that, there is something that needs to be done after aligning mirror 3 that I didnāt do beforeā¦
Maybe a combination of that and possibly the close and far beams being a little (1-2mm) lower on the entry to mirror 3?
The middle of the mirror on the head might not align with the center of the nozzle.
Did you try removing the lens and nozzle and putting tape under it to make sure the mean is aligned with the lens axis?
I havenāt yet but I will try that too. In saying that, I have just produced the below at 30% (beforehand I was getting this result at about 15%)
That one looks great. Was it in the same location on the bed?
Your % reading on the digital panel may not be the same as before with this new laser. However 15% change does seem like alot.
I found Slate to be pretty unpredictable as the material is irregular and varies in thickness and roughness
To test I would engrave on something more predictable.
yeah, the above one was @ 30% at the same location. It seems weird that it turned out so well and the others were faded. I understand a different tube may have a completely different output as well but Iād figured the new one would have been better than the original
I suppose like when I originally got it, there is going to be quite a lot of playing, experimenting and wastage!! Looks like all the settings I had for the slates before will need to be revisited
Back to alignment again folks. The attached pics show that along the bottom of the cutting bed (30x20cm) the laser seems to be splitting into 2 beams. The pink paper seems to have attached as landscape so the bottom is actually along the left side of the attached pic. I did this with the bottom of the laser head off. The effects of this are in the 2nd pic when I vector engrave letters. You will notice the āGā has defective lines which I am assuming is due to the beam being split? Any suggestions? It also seems that along the bottom of the bed (more so toward the bottom right) that the raster effect fades considerably.
Usually when you have a significant power fading over the range of your bed that either means an alignment issue or the bed isnāt level.
With a split beam there are several typical causes.
So what youāre saying maybe is to look at the alignment again possibly as this split is only happening in certain areas? Splitting anywhere ācouldā be as a result of misalignment? It is also a new tube but I do understand that means nothing either The beam firing onto mirror 3 is a LITTLE low of centre so maybe I need to raise the tube a tiny bit and realign all over again?
If the beam pattern looks right using witness paper in front of the first mirror, then itās unlikely to be in a higher TEM. Iād suggest taking pictures of witness paper before mirror 1, before mirror 2, before the head mirror, at the bottom of the tube with the lens removed, and at the bottom of the tube with the lens installed, and post those pictures here at high resolution and carefully labeled.
My guess is that your tube is not parallel to the gantry and is pointing uphill or downhill.
Its common to have this problem with a new laser install.
Itās hard to see what is wrong unless you target at 2 places along the beam path and between mirrors.
