Thanks Michael, I understand the advance of a open discussion and information exchange, but sometimes you got no answer or do you want to ask some questions how are not really interesting for everyone. That’s the reason, why most often a forum use a PM system. Some people use the system not so often and by using a PM you can ping someone for a questions. Sure only if an email auto notification is in place and activated.
Did anyone have some experience with L7 model from vigotec? Is it possible by using more than 1 turn (2-3 times the same route) cutting 4mm poplar wood or other softwood? What I got on information out of the forum is: The delivered software needs a USB doogle to start! It has a firmware based on is a GRBL 1.1f version. Can someone confirm that the laser works also with LaserGRBL? …or other software?
Thanks a lot for your time and information in advance. Excuse my terrible English it is not my native language
This site has email notifications for public posts. If you don’t get a response in public, sending a PM is just pestering. There’s no difference in email notifications between public and private messages.
When you decide that your question couldn’t possibly be be interesting for others, that is making a decision on their behalf. Our community standard on this forum is that questions belong in public, and the judgement of whether the question is interesting to any particular reader is the proper domain of the reader, not the writer.
There are legitimate uses for direct messages on this forum. An example would be if agreeing to exchange hardware, direct messages would be an appropriate way to exchange physical mail addresses. But taking questions to DMs goes against our community norms. “No one answered my question” is not an OK reason to pester people with direct messages. Everyone who posts here does so on their own time, for free, and no one is under any obligation to respond to any question.
I don’t have any experience with Ortur or Vigotec machines, but I have a “5.5W” chinese diode laser (in a self made case). I can’t get through 3mm poplar (even with many pathes) and the edges get completely burned after a few pathes.
The problem is not the wood, it’s the glue between the playwood layers. It might work to cut thin inlay/veneer wood and 2-3mm balsa (but balsa quickly get realy dark edges).
Well, i have a VG-L7 20w since January, its a pretry cool machine for engraving fun or to do a small business. Normally the software came with those laser machines are a little bit limited as for exemple if you want add a grayscale photo to the galery is quite difficult.
You can work with others free Softwares as LW4, GBLR, or, pay a anual fee to use LightBurn (its a good program too).
I recomend you to use GIMP and Inkscape, if you want work, change, resize, etc images for free.
After all this months, i came across with a LW4 problem when i lasering a image. Some how my laser stops in the middle of the job and LW4 crashes. Its something didnt happen before, is anyone have a idea that could provoque this?
Hello Dennis,
I also bought the same device just a few days ago. Have you already solved the issue about VigoTec crashing on dxf files? I am encountering the same problem and I’m not sure what seems to be the problem.
I have a Vigo L7, and I have made it do great things. You can easily get the software for all the machines at vigotec.cn
I have made my L7 cut 1/8" Kydex, 1/4" wood, leather, and other plastics. I am a computer graphics specialist, and a graduate machinist, so I understand these machines better than most. Please dont ask me g-code questions, as its been 20 years since I’ve had to use it, lol. I use the L7 to burn onto just about everything.
I am a maker, and have many different machines here, in addition to the following lasers: 5 lasers total, as 2 L7’s, a rotary 15watt for burning onto round objects, a BX20-2.5w type that I can now dedicate to engraving with its motor, and a 7watt that is similar to the L7, with an integrated screen.
Feel free to ask me anything, and I will attempt to answer.
The way that I get images into the L7 is with Corel Draw and Corel Paint. I first type the font in Corel Draw. I then pick it up by copying the text, image, whatever was done, and then click over to Corel Paint. In paint I go to File-Create from Clipboard. This makes a new image that is just the size of what you clipped. Save this out as a JPEG or whatever system format you need it in and you are good to go. This makes it so that I can go to a party and burn a plaque for each person in around 5 ins time.
There are other paint and drawing systems that do these same operations.
Glad to meet you all, Have Fun!
-Doc
Hello, i bought Vigotec VG-L7 recently and now the Weak Light is not working anymore but the laser is still working but i cannot use it since it is hard to position the image without the Weak Light. Please help me to resolve the problem. Thank you
Hello, I just received my vigotec but I am in trouble with the software. I would like to run the laser with lightburn, you said it is possible. Can you please tell me how I have to do it? Thank you
Sorry to e-mail you directly but, I could not find where on the forum to start a new topic and you seem well educated on the lasers. My question is; with the vigotec BX20 laser, how can I make some areas of a picture Shaded instead of the same darkness and same burn depth as the main image? For example, a picture of Jesus. I want a well defined face but, shading on the vheeks
Help me please! I got this machine and messed up the firmware. I set the X-axis travel resolution in steps per millimeter parameter in the LaserGRBL program. and Y-axis travel resolution in steps per millimeter. Not the right one. What are the factory parameters?
Hello Kath;
I don’t know if you are still having trouble with DXF files or not. I have been able to import simple DXF files. I have the same trouble with larger files.
I use Qcad to manipulate the source DXF file to isolate only the element that I want to cut with the laser. I create a number of smaller DFX files, one for each printable area. I made sure that my DXF file was converted to mm dimensions before I created the small DXF file for import into the VG L7X software. So far, I have had good luck importing the small DXF files. If I am careful with the dimensions, staying in mm, the files import at exactly the same scale as the source DXF file and I can cut the parts to scale.
