Some advice on a slight overhang.
While printing a slight / small Overhang, the nozzel seems to miss the edge of the last filament laid down filament.
Drops off the edge. Printing in PLA , 195 temp & printing slow 40mm/sec. Fan on 100%
Can not understand because usually don’t need any support for small overhang. printed the part before with no problems, now its just falls off the edge.
Are you printing with a taller layer height than normal? Or perhaps you might have some mechanical backlash?
No not printing any higher. Same layer height
Maybe slight underextrusion causing the extruded width to be slightly less? Try increasing the amount extruded by what ever means you prefer.
Thanks Guys
