I have 2 problems that are related, but opposite. I’m periodically underextruding.
I’m noticing periodic slippage and skipping steps in the extruder of my Printrbot Simple.
I’ve marked the bearing with lines (using a marker) and can see that sometimes the bearing isn’t turning (and sure enough, the line thins out) but only for a second or 2 and then it goes again.
I also sometimes (and this is independent of the first symptom) hear and observe the stepper skipping steps.
I have cleaned the teeth on the hobbed wheel, and increased the tension, but there’s still period stalling of the feed.
I have increased the current to the stepper, and it now runs much warmer, and there are still times when it skips steps.
Partial clog might explain the skipping steps, although it’s so brief that it barely shows up in the prints. That happens somewhat randomly.
The “slipping” seems fairly rhythmic - I’m wondering how long the hobbed gears last. As in, I wonder if some of the teeth are worn and not biting as well?
I just switch to a new spool of filament. We’ll see how that does.
@Alexander_Pritchard Kinda tried a cold pull just now (switched filaments again). Could not pull filament out until head reached ~100C and then the filament just snapped off inside the head.
I did crank the heat up to 213 and it seemed to extrude very smoothly. Maybe this PLA (black) just needs to run hotter…
@Alexander_Pritchard That might work - except I don’t have a base feel for normal back pressure. @Keith_Applegarth I printed a couple small parts with some left over black PLA from a different supplier, and it seemed to work better. Might have to re-slice at a higher temperature. (Would be nice for host/firmware to support a temperature variance so you don’t have to reslice just to tweak head temp).
Just found out that Repetier Host lets you adjust the temperature on the fly. I was printing at 195, resliced and started printing at 197 (probably too small to make a difference), then saw the “slider” on the temperature gauge in RH. Bumped it up to 203. The bearing is still stalling periodically.
I have ordered a new hobbed pulley to make sure I get a good bite, and a new nozzle. Printrbot recommends changing the nozzle every 6 months - not sure how many hours or meters of filament that might be. I’ve run almost 10kg through the original extruder and hotend.
So while waiting for parts, I’ve continued to observe (when around) and tweak. Running the black PLA 5-7C hotter (203 vs 195) seems to reduce the problem almost to the point where I’m wondering if it is happening or not. The parts I’m printing don’t have a lot of fine detail requiring retract/prime steps, so I’m not sure how bad the higher temps will affect stringing, but for now I’m printing without the extruder clicking and the bearing seems to keep on turning.
