Need some of your combined experience and knowledge. I print in PLA (195-210 depending upon filament) on an unheated bed. I am having a fair few issues with layer adhesion and bed adhesion. This all started as the temperature dropped, bloomin’ winter
My house is a barmy 9-12 degrees centigrade at the moment, I am too cheap to put the heating on.
Would that environmental temperature have an effect on 3d print builds? Trying to narrow down the causes. The other potential causes are being addressed as I learn more about 3d printing.
Environment definitely does affect prints. In winter adjust my prints warmer by about 5’C although I live in Johannesburg. Where winter is between 5 -15’C snow is something we see in movies. Advise you to get a heated bed. I run it at 40’C and 45 in winter I makes a difference.
@Ross_Bagley Thanks Ross, I will see what I can figure out, perhaps I can create a acrylic enclosure.
I was sort of hoping it could be the ambient temp, I have tackled every other potential problem and was getting a little frustrated. Luckily I am pretty motivated
Just go get a huge storage bin and enclose t. You would be surprised the head that retains. If your bed is too cold you might need to find a way to heat it up beforehand. I like in southern US so I never really have adhesion issues.
@Griffin_Paquette Yes, that works amazingly, I have a pb simple makers, no hot bed, in a huge storage bin turned upside down, and my bed gets toasty all by itself
Humility is not a huge problem here. We have dry winters here and I do see my filament lasting longer outside (the box not the house) than summertime. But I think the point here is more heat in winter to make up for temp drops. Seeing as we’re about to change I need to keep in in mind printing.
Finally bought one of those halogen room heaters, brought my room up to 18 degrees and all of my problems are solved. Fantastic results so far.
As far as I know the Flashprint software doesn’t allow you control the fan manually which is a shame. Going to have to invest in something else soon enough.
