just an observation: your X axis drive pulley looks like it’s a rather small diameter and was it ruled out that the period of the curtain waves was not the same period as the belt? Also, are these pulleys pressed on or do they use grub screws? Grub screws can cause an offset in the pulley imparting a wobble as it rotates.
So long as the number of teeth are accounted for in the calculation for steps per mm, does the diameter of the pulley matter? or what would the diameter of the pulley effect besides steps per mm?
Not specifically. Do you have some instruction on how to do this?
They do use grub screws. The inner diameter of the pulley matches very closely with the shaft of the stepper. I will check tonight if there is wobble in the pulley as the x axis moves along.
You had implemented Russ Sadlers inverted belt mechanism but you didn’t watch his video explaining why? Did you notice how he talks about small diameter pulleys and goes over what belt type is good and bad for small pulley diameters? https://www.youtube.com/watch?v=QFLq14vY2zQ
and this Russ Sadler video talking about the same Curtains issue and his solution and again, why: https://www.youtube.com/watch?v=B87ifTPKN8c
FYI, it’s how the teeth of the belt interface with the drive gear which causes some variation in belt/pulley position and a very small gear will show this more than a larger diameter gear. But also you’d have seen there are different styles of belts and the gear drive must match the belt design. I was rather perplexed when you’d implemented the inverted belt system and then removed it… The video not only explained why it is a desirable design but also that it works. But if your drive gear design does not match your belt design you’ll still have poor control and if your drive gear pulley wobbles from not being pressed on but being grub screw with wobble the improved inverted belt system will still not fix your problem…
And look at what this fellow had because of time belt interface issues and yes I know this is not the design you have, it’s just showing you the results of poor belt/pulley interfacing. https://www.youtube.com/watch?v=7BrQZQDj_0Q
Instructions? you measure the period of your curtain cycle and you measure your tooth to tooth belt distance and compare.
if it is wobble of the drive gear due to an offset wobble then your period of the curtain will match the period of a single rotation of the drive gear. ie it won’t be ~2mm if you are running GT2 belts(2mm tooth spacing) but will be closer to the diameter of the gear at the belt to gear interface.
Still not sure about this. The curtains are 6 mm apart. I have a GT2 belt. Periods are time related. The distance between the gt2 belt nubs doesn’t have a time component to it. How can there be a period?
I was able to capture a video of the x axis pulley rotating. I don’t have a basis for comparison, but this does t really look like it is wobbling:
Edit: That video RDWorks Lab 83 was amazing. I never saw that video. Much more respect towards Russ than I originally had.
You said before that there was no change when you ran at different speeds. If they are time related then they should be different distances apart at different speeds, and also would be unlikely to line up like that.
There are 16 teeth on the pulley. Also please don’t take my word for whether or not they change with speed, my opinion is biased. I read through this entire thread the other day and looked at all the photos I have posted. I think this post is the most interesting visually:
If it was electronic and based on the speed, the pitch would be different.
6mm is 3 teeth; I asked about the pulley wondering if the pitch of the pattern was an even divisor of the number of teeth on the pulley, but no 3 doesn’t divide evenly into 16.
@dougl@mcdanlj
A while back I mentioned I thought I might be fighting multiple demons. I think I may have identified some of them.
Firstly, I understand that the teeth and pattern spacing didn’t line up perfectly. I gave a number of 6mm, which is my best guess (I think it was difficult to identify which spacing to measure because there are actually overlapping patterns). Lets say it was 8mm or 4 teeth, that would be in sync with the pulley rotation and fall in line very will with Russ’ explanation.
That being said I switched the X-Axis pulley to a 36 tooth pulley and seem to have some better looking burns. Thanks @dougl , I think you found one of the harder to identify issues. There are still two other issues that have been overlapping with the pulley issue the entire time.
Oddity 1 (solved):
Possible glue trowel marks / weirdness in between layers of plywood:
There are 3 burns done in this image. From left to right the acceleration values of the x axis were increased by 500mm/sec2. The left is 1000mm/sec2/ middle is 1500mm/sec2 and right is 2000mm/sec2. As you can see, the 1000mm/sec2 burn (the burn with the most changes in speed) is very reminiscent of the “curtain” effect, but looks close to a gradient. It should not be a gradient, this should all be burned to the same extent, but with the speed changes, the controller is attempting to adjust power, but is not doing well. This leads to some stripes/curtain looking effects. it gets better in the second burn, and a little better in the last burn. That is because the head speed is more constant as it truly reaches the desired speed sooner due to the higher acceleration values.
I then did a burn with a very large overscan to see if the burn remained consistent without power level changes:
This turned out really good. All of the speed changes occur outside of the burn area, hence no power level changes during the burn.
So the question is, are there any good ideas on how to make the laser power more linear? I know that FluidNC has the speed mapping options, but are there any good ideas about how to find the numbers to set them at? Is there something I can do with the potentiometer that can help here?
Wow, they really went through a lot to get to a final solution. Adjusting my laser power has very easily solved the problem of hitting in between where the oddities are.
I just gotta get laser power scaling properly and I think my overall problem will be solved.
It’s a very long thread but way back near the beginning the OP stated he’d installed the same mechanism but said it didn’t change anything so he removed it and put the machine back to the stock configuration.
In Russ’ videos he mentions three main solutions to this problem that I picked up on:
Bigger pulleys
Slower Speeds
Belt Inverter Mechanism
@dougl Mentioned that my X axis drive pulley in particular had a small diameter. This was the easiest thing for me to try. Which I did, and I saw a pretty big improvement.
I also had vibrations in my bed and plywood layering issues. These three things stacked up against me pretty badly.
I have managed to get the laser power scaling adjusted correctly and am getting some decent burns out of the laser now:
After having watched Russ’ videos a few more times, I noticed my design has a slight but very important design difference. The motor pulley in my design still has the belt wrapping around the pulley versus Russ’ design has the motor pulley pressing against the belt pulley:
I think if I were to properly implement his design, I might be able to use a smaller pulley. I’m not sure if it is worth it though as right now the machine is working pretty well and I did implement a different solution that Russ says is equally valid.
Glad this is resolved for you! I’m not sure which post you should mark as the solution but maybe that most recent post you just made that summarizes all your changes? That will communicate that you aren’t looking for more diagnosis here.
