Does anybody have a problem with the extrusion widths in CURA 2.3.1 or higher version?
It seems there is an issue where the extrusion widths jumps from almost 0 to also 0.50 mm in the resultant GCODE,when you expect a somewhat consistent
extrusion width when printing with a 0.4mm nozzle, and 0.4mm extrusion width settings.
We don’t see this same behaviour in Slicer for similar settings.
Here is a visualization of the GCODE Produced by CURA:
I used the Old 15.04 Cura. Which doesn’t visualize it perfectly, due to a bug (some layers are missing) But I knew it would calculate the widths from the GCode.
