Anyone knows a good guide for calibrating a Delta printer?
Delta printers are a whole class of printers, based on a Delta Robot concept. They are not Cartesian, the three axis are all coupled together and cannot be calibrated separately.
Here is a Delta printer call Cerberus, it is similar to what I’m building - http://reprap.org/wiki/Cerberus
Following
I sugest you make sure your build is as accurate as can be. If you are spot on with the build there is really nothing to calibrate except of course extruder. When you are sure you can’t make it any better go trough the site @Jeff_Karpinski pasted earlier.
