I’m attempting to put Marlin 2.0.4.4 on my X5 Mini but I’m running into an issue.
[platformio]
src_dir = Marlin
boards_dir = buildroot/share/PlatformIO/boards
default_envs = LPC1769
// Choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD BOARD_AZTEEG_X5_MINI_WIFI
#endif
Error:
Executing task in folder Root 3 CNC: platformio run <
Processing helvepic32 (platform: microchippic32; board: helvepic32; framework: arduino)
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Microchip PIC32 1.6.1 > HelvePic32
HARDWARE: 32MX250F128B 48MHz, 32KB RAM, 120KB Flash
PACKAGES:
- framework-arduinomicrochippic32 1.20006.0 (2.0.6)
- toolchain-microchippic32 1.40803.143 (4.8.3)
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 29 compatible libraries
Scanning dependencies…
No dependencies
Building in release mode
Compiling .pio/build/helvepic32/src/main.cpp.o
sh: /Users/bcramer/.platformio/packages/toolchain-microchippic32/bin/pic32-g++: Bad CPU type in executable
Compiling .pio/build/helvepic32/FrameworkArduinoVariant/Board_Data.c.o
sh: /Users/bcramer/.platformio/packages/toolchain-microchippic32/bin/pic32-gcc: Bad CPU type in executable
Compiling .pio/build/helvepic32/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/helvepic32/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/helvepic32/FrameworkArduino/Print.cpp.o
Compiling .pio/build/helvepic32/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/helvepic32/FrameworkArduino/Tone.cpp.o
*** [.pio/build/helvepic32/src/main.cpp.o] Error 126
*** [.pio/build/helvepic32/FrameworkArduinoVariant/Board_Data.c.o] Error 126
*** [.pio/build/helvepic32/FrameworkArduino/HardwareSerial.cpp.o] Error 126
Compiling .pio/build/helvepic32/FrameworkArduino/USB.cpp.o
*** [.pio/build/helvepic32/FrameworkArduino/IPAddress.cpp.o] Error 126
*** [.pio/build/helvepic32/FrameworkArduino/Print.cpp.o] Error 126
*** [.pio/build/helvepic32/FrameworkArduino/Stream.cpp.o] Error 126
*** [.pio/build/helvepic32/FrameworkArduino/Tone.cpp.o] Error 126
*** [.pio/build/helvepic32/FrameworkArduino/USB.cpp.o] Error 126
============================================================================== [FAILED] Took 1.07 seconds ==============================================================================
The terminal process terminated with exit code: 1
Terminal will be reused by tasks, press any key to close it.
