Wouldn’t it be nice to work on entire sets of leds at once? People keep asking for it, and I think I found a way to do it that I’m happy enough with. Imagine if you could write:
leds(0,4) = CRGB::Red;
to set the first 5 leds to be red. Or what if you wanted to copy the contents of the first part of your led array to the second part?
leds(10,19) = leds(0,9);
why don’t we mirror it, instead?
leds(10,19) = -leds(0,9);
and let’s fade everything out the way we like to:
leds.fadeToBlackBy(32);
what about some math?
leds *= 2;
or let’s just do that on some of the leds
leds(5,9) *= 2;
let’s put a rainbow on our leds:
leds.fill_rainbow(hue++);
or, again, just on a subset of the leds:
leds(10,14).fill_rainbow(hue++);
Welcome to CRGBSet - https://github.com/FastLED/FastLED/wiki/RGBSet-Reference!
The heart of the CRGBSet is the ability to take a subset of leds, and a subset is defined as being the first led and the last led you want in the set. So:
leds(10,14) starts at led index 10 and ends at led index 14 and has 5 leds in it - 10,11,12,13,14. Of course, you can reverse that and say leds(14,10) - which still has five leds in it, but leds(14,10)[0] will be led 14
Once you have a set of leds, you can do all sorts of things to them. How do you get that first set of leds? Simple, you slightly tweak your led creation:
CRGBArray<NUM_LEDS> leds;
Now you have a CRGBSet that represents all your leds. You can then take subsets of it. leds(0,9) returns a subset of the first 10 leds in your set of leds - this subset is also a CRGBSet - which means you could, in theory, take a subset of that!
Want to duplicate the leds from the first half of your strip to the second half?
leds(NUM_LEDS/2, NUM_LEDS-1) = leds(0,NUM_LEDS/2-1);
What about mirroring? That’s easy, just reverse the ordering of one of the sets:
leds(NUM_LEDS/2, NUM_LEDS-1) = leds(NUM_LEDS/2-1, 0);
Pretty much everything you can do to a CRGB you can do to a CRGBSet. CRGBSet also has fill_rainbow, fill_gradient, nblend, etc… methods on it as well.
Still adding to this - now there’s support for C++11 ranged for loops (if you’re building in an environment that supports C++11) - for example to set pixels 8-10 to random colors:
for(CRGB & pixel : leds(8,10)) { pixel = CHSV(random8(), 255,255); }
Of course, you can do this over all your leds:
for(CRGB & pixel : leds) { pixel = fadeToBlackBy(40); }
(which is equivalent to leds.fadeToBlackBy(40);, but just wanted to show this stuff off)
This is VERY VERY alpha code. It probably has bugs, it is probably incomplete. It might set your house on fire. Use at your own risk.
And have fun!
[ETA: And now i’m going to be out for much of the rest of the night - split even odds on me responding to comments in the next half hour, code updates are right now. It’s like tossing a live grenade into the playroom just before stepping out for lunch :]
