New project I’ve been working on. This particular pattern is from Mark’s Twinklefox code. Everything is controlled by smartphone using an app called Blynk. I think I have around 25 animations and 30 color palettes currently programmed.
@Jeremy_Spencer Thanks! I purchased it from Target as a bare bones advent calendar. Had to drill a bunch of holes and add some paint to it. It is a polished steel with a copperish looking plating.
@marmil Thanks Marc. I would definitely agree with you. Some of the animations look better with the diffuser others without. I need to devise a way to make the diffuser easily detachable depending on my mood and animation and not be ugly. Currently attached with clear tape…
@Brian_Lewis I was thinking he same thing- but it’ll be such a pain. Too bad you can’t slice a cross section through the metal part and slide the diffuser in between
@Cristian_Martinez yeah for sure. I’ll post the code on GitHub tomorrow. I use a local blynk server so I don’t have to do any in app purchases. PM me on Instagram and I can help you out if you want
