I have not seen this anywhere… where did you find this?
Keeping the temperature under control and following your logic, if I have a 20mA maximum current limit, it’s ok if I run it at 40mA for half the time or … 60mA for 1/3 the time? … I don’t think so and I think you’d agree … Tubes are designed to operate at various current levels, unlike a ssl. These, K40’s are configured to be run by a system that drives ssl, not tubes.
No need to argue the 60mA/time is pretty ridiculous … When you set the current level like this with a dc voltage, when it lases it lases at 100% and it’s accumulative. 100% of the time these lase, they lase at 100% power… or whatever your dc voltage current limit is.
Most of these low cost tubes have at least a 2000hr expected life time (MTBF). You’ll notice that to get this life, you have to use it <40% power which is <12W… I use mine, mostly in the 40 - 70% range, but I cut in the high end. You end up, if over 70%, almost a 75% loss of tube life.
The Ruida will run other than 100% power continuously, not true with the standard grbl type boards for a ssl that the Chinese use. Most of them are copies of western world controllers, similar to the Arudino… software was probably hacked western world open source.
All information I’ve ever seen, including on this site and every where else is don’t over drive the tube and it’s always directed at the current flow. All information I have says current is the main cause of damage to a tube.
I agree, that heat, is an issue. Anytime you want something to work faster chemically, you generally heat it up for faster reactions. I think my tubes life was shortened substantially in Phoenix as we had a very long stretch of 53 days that the outside temperature was 110F or higher. My co2 machine lives in the garage … No a/c
Some of these people claim to have gotten extraordinary life from these K40 configuration and I have no reason to suspect otherwise.
Operating normally, the guys with all the degrees say it’s down to how well aligned the mirrors are in the amplification area, will dictate how long they last… This is way over my head, but thought I’d throw it in anyway…
I’ve notice more of the K40 types are configuring pwm to drive the IN terminal and using L or H for a laser enable. They shouldn’t lase if there is a 0 voltage driving the current limiting circuits of the lps.
If I configure my Ruida for an RF source, it operates like it’s driving a ssl, there is no laser enable in that mode. No pwm, no lase, same lps.
At least that’s my view… hope you’re not sleeping by now…
