Hi again,
I have replaced the tube on my K40 after an unforunate freezing mishap but thiink the new one from Cloudray may be faulty. I have spoken to someone at Cloudray and sent them a video of the tube working which shows it never gets above 4-6 mA at 99.9% on the digital readout. I have switched back to the M2Nano board from a Monport board as this was suffering the same issue so i thought this a valid experiment.
Cloudray have asked the Following
“What is the voltage of the laser power signal measured on the laser power supply? When using 99.8% power, the measured voltage should be around 4.8V. If the voltage is abnormal, unplug the laser signal plug on the laser power supply, press the LASER button on the laser power supply, and capture the discharge status and current size of the laser tube.”
As i am fairly new to all this, can someone explain where i should be taking these measurements from on the LPS please? I am using this model LPS
Happy to provide any further information required.
thanks
