Slowly working on disassembly. Thanks to the internet, and the love people have for vintage Craftsman tools, I was able to find a copy of the original owners manual. Complete with exploded parts diagrams. It’s made the disassembly a lot easier.
Got it pretty much disassembled. Finally got to get a feel on the individual bearings. One of the pulley bearings feels fine but the other is a bit stiff to turn so the lubricant has probably dried out some. The top spindle bearing seems fine but the bottom one near the chuck defiently has some roughness. Since I have it broken down, probably just going to go ahead and replace all four.
Been slowly working on derusting the parts in batches and went to look at starting the process with the chuck. Sprayed some liquid wrench on it and went and got the chuck key, that I spent time restoring, to see if it would move at all. Lol the key didn’t fit
The pilot hole in the side of the chuck is 5/16" while the pilot on the chuck key is 3/8". Should have spent more time looking around that old shop because there had to be another chuck that this key fit. Oh well just another $11 for a new key.
Not sure. The chuck is setting in a vinegar bath at the moment. Don’t have a metal lathe currently, on the wish list. Would probably be “fun” to get that mounted in a 3 jaw lathe chuck though
Yeah I saw that 4-way key but I don’t think it’s the best quality based on some of the reviews. Also I would think it would be rough on the fingers. I found a Jacobs brand key on ebay for $8 delivered so I ordered that.
Got it derusted. Hot soapy water scrub down to remove oil. Vinegar bath overnight followed by wire brushes on dremel. Sodium bicarbonate (baking soda) bath to neutralize residual acid, water rinse, dried in toaster oven at 200F to drive off residual water and then oiled. Works just fine,
Still will need a sanding and polish. Would like to take it apart to fully clean and regrease, but I need to see if I know anyone with an arbor press I can use to get the outer collar off
Got the quill all cleaned and polished tonight. It wasn’t too bad. Mostly a light coating of rust mixed with some old hard, almost baked on like, grease.
Really the next steps are the big parts: motor, base, pole, table and head.
Still debating on how I’m going to derust the cast iron head. The inside of the head has the most rust, which is also going to be the worst areas to get to. Could soak it in a big bin of vinegar and then go at it with wire brushes, but I’m also considering the electrolysis route.
Today’s project ended up being the aluminum drive pulleys. Used wire brass wheels followed by a buffing wheel on my bench grinder to clean up the powdery oxide. Cleaned up nice.
