MKS DLC32 V2.1 : Speed control of spindle
Hi and greetings from South Africa.
I bought a CNC from a guy who builds it and he used this specific board for my CNC machine. What I don’t understand is that he added a Variable Frequency Controller to control the spindle. I have to switch it on here and also set the speed after dividing the required speed by 75.
From videos I have watched, it seems that there is no need for this frequency controller and that the spindle is switched on and off in the GCODE.
Another builder told me that the frequency controller is not necessary as the board can do that by itself. I don’t want to switch the spindle on and off on the frequency controller. This must be done by the gcode.
He soldered all the wiring onto the back of the board and didn’t use any of the sockets for it.
Can you please confirm that the board can do this and that no Frequency Controller is required?
I want him to redo the wiring so that I don’t need the Frequency Controller.
Thanks very much.
I’d suggest not to buy this type of hack. Don’t mean to be derogatory, but when you have connectors, do it right, not a hack job to get it running.
It shows little insight into maintenance or debugging of hardware problems.
It’s prone to inducing wiring errors.
If the board fails, it will be a can of worms so to speak.
The DLC32 puts out a spindle control voltage or pwm output that is for spindle speed control. I don’t know what this output is, offhand, but it’s schematic is on github and I think it just completes the ground when it’s on.
I have no idea of the kind of spindle you have or it’s requirements, without that I can’t offer much.
I had a CNC3018 that I upgraded to a 500mW spindle… That required a control voltage encompassing 0 to 10V. I picked up a pwm → analog voltage board which sort of worked. It being a 12V system the converter board could never quite reach 10V so no 100% speed. It does work fine with a 24V supply but added complexity.
You need to supply some information of what you are driving… not all spindle or spindle control signals are the same… but are similar.
What is the manual adjustment, an external box or ?
Good luck
:smile_cat:
As @jkwilborn suggests we need to know what kind of spindle motor you are using.
If it is not a DC motor you will need a VFD and that may need manual speed adjustment.
Hi and thanks so much for your replies.
The board is driving a spindle.
The Frequency controller is controlling the speed of the spindle. Whatever the speed must be, must be divided by 75 and that number is set on the Frequency Controller by turning a knob.
Thanks again.
Deon
A link would surely help. We need more information on how the device is controlled… like how the part you dial up the speed is connected.
:smile_cat:
You are right, thanks.
Here is the link to the spindle. It uses a VFD.
Here is the link to the Variable Frequency Drive.
I see this at the last bullet of the features, which means the guy who built my CNC Machine did not wire it to work with a signal from the board.
Thankx again for your help.
  • Control: By hand via built in control panel or via digital signal from controller board.
Thanks again.
This spindle motor needs an AC drive (VFD).
From the manual below:
If you want to control the motor speed this vfd can be controlled by a 0-10V analog signal.
In this config. you will need to convert whatever control signal you decide to use on the DLC32 to an analog 0-10V signal and then program the VFD to accept that signal.
If you just want to turn the motor on off at a fixed speed, you can use relay interfaces.
I suspect you can learn more by doing a search on which configuration you want to pursue.
Info:
https://mega.nz/folder/LklRBKBC#h1-13n5KtAnH67VqTvKpDQ/file/nssAyTDA
Thanks for all the replies. the guy from whom I bought the machine, is a crook so I have decided to return it.
