I’m not actually planning to laser-cut this; I’ll be routing it on my OX. But if I had a laser, I’d be using it, and I know that that’s the general range of thickness for cutting wood with a 40W laser, so asking here…
What kinds of stores local to you do you go to in order to purchase thin plywood? I can’t get thinner than 5mm at the big box home improvement stores. I have some fairly simple shapes I need to cut, but no stock.
I have a couple of local hardwoods lumber yards that sell veneer in multiple thicknesses, which can be just lovely to work with. (It can also be miserable because the really thin stuff is hard to keep flat enough to stay in the focal range of the laser.)
