Hello,
I am a newbie to K40 Whisperer.
I was happily using LaserDRW when after Yesterdays W!n10 update, nothing works. After trying everything, i found a post about the Whisperer Program.
I Installed it, with the USB Driver etc. and everything seems to be working.
However, when i do a simple design in Inkscape, save and import that into Whisperer, it either shows a Black Square or a clear white square, no image.
Can anybody help me?
Just as info, yes i have Initialized the laser and yes it moves my K40. if i drag the white or black square around the workspace, the laserhead also moves. so i am pretty sure they are communicating ok. i just cant seem to get any image to show in the app.
Hi,
Thanks for the reply.
I used that sample file, it works in the app.
I also opened the file in my Inkscape and saved it as another doc, it still worked in the Whisperer app. so I am a bit lost there. I uploaded a sample file on the previous reply.
Hi all,
happy Sunday.
Ok, so lets start, it seems to all be working now, thank you for any and all assistance.
Because i was still using LaserDRW, the plugin that allowed me to save In LZR format only worked in Inkscape 0.92 !! yes i know, wow, when was that? Haha.
Anyway, Since i figured out that i dont HAVE to use LaserDRW and i dont necessarily need that idiot dongle plugged in, I downloaded and installed the latest stable version of InkScape.
Let me tell you, what a shock.
consider this topic solved and i will return to my desk and start learning.
I thought i was quite proficient in the old Inkscape. I managed to copy and recreate all the things thet were currently being done in my old version.
Have a fantastic day and once again, thanks for the advice.
Hi Michael,
when i looked through this and saw the references to the version … 0.92, i got the feeling this was where the issue was.
Thanks for the help
