I am hoping by replying to the last message, this update will post as I still cannot login to the site.
Please find the results from connectivity checking:
I did find that there was a poor ground wire earth connection
<img width=“521” height=“442” style=“width:5.4305in;height:4.6041in” id=“Picture_x0020_9” src=“/uploads/default/original/3X/b/7/b760e2990d117df5a55788ff6358a3efbe7b95bb.png” alt="A hole in a blue surface
Description automatically generated">
So I scraped off the paint both sides and re-secured the ground wire earth to include 3 washers
<img width=“447” height=“511” style=“width:4.6597in;height:5.3263in” id=“Picture_x0020_8” src=“/uploads/default/original/3X/d/e/de5b9e933f97ff5314d1388990e21e8472cf0365.png” alt="A hole in a metal surface
<img width=“437” height=“452” style=“width:4.5486in;height:4.7083in” id=“Picture_x0020_7” src=“/uploads/default/original/3X/5/6/56b65ed58d3b5899353b0fee199eedc4e5898cb9.png” alt="A hole in a blue wall
<img width=“417” height=“360” style=“width:4.3402in;height:3.75in” id=“Picture_x0020_6” src=“/uploads/default/original/3X/a/c/acc714c0996838a0f4f16de722bd2002a26575c6.png” alt="A close-up of a blue box with wires
<img width=“412” height=“455” style=“width:4.2916in;height:4.7361in” id=“Picture_x0020_5” src=“/uploads/default/original/3X/5/9/5930f71b9c8d0ce9bd6a3dafa4bb28d929f87a8c.png” alt="A metal bolt with a hole in the wall
The cathode tube connection looked ok so did not remove the silicon tube
<img width=“391” height=“522” style=“width:4.0763in;height:5.4375in” id=“Picture_x0020_4” src=“/uploads/default/original/3X/3/b/3b5a6cf9a288dfcc58ff364263473d4391c7ebb5.png” alt="A close up of a glass object
The anode connection looked ok and seems to connect inside the tube
<img width=“384” height=“512” style=“width:4.0in;height:5.3333in” id=“Picture_x0020_3” src=“/uploads/default/original/3X/2/2/220d93ab3a868a123cb394e6fffbfe6446f9affc.jpeg” alt="A close up of a device
The wire was simply wrapped around the anode pin . No solder just silicon tube with silicon
<img width=“480” height=“640” style=“width:5.0in;height:6.6666in” id=“Picture_x0020_2” src=“/uploads/default/original/3X/b/f/bfd9291a470300e655314e90f7c4a90faa37ec68.png” alt="A close up of a wire
There seems to be no damage to the pin and it does seem to connect inside the tube
These are the instructions I have taken from the site to re-wire the anode:
At the Anode end of the laser tube
· Remove the silicon sheath from the anode connection. Minimize forces on the anode pin. It should pull off but if not you may have to cut it off.
· Your anode wire may be twisted, screwed or soldered on the anode pin.
· Remove the old anode wire.
· Replace the anode wire in the same way it was connected, twist, solder or screw.
· If soldering use minimal heat. Some recommend using Teflon tape to hold wires that are twisted see video below.
· Route and restrain the wire in the same way. Usually tie wraps around the tube moving away from the anode end toward the cathode end.
· Flow silicon around the anode wire connection (use the white tube that came with your K40)
· Push the silicon tube over the wet silicon filling the tube. If you had to cut off the tube you will need to replace it with a piece of silicon tubing.
· Add more silicon to the top of the silicon tube if needed
