hi forum, i got mks sbase v1.3, i want to load firmware (cprezzi) and i can’t, i downloaded mks_sbase_firmware-bin, i copied files inside mini sd 2gb formatted in FAT, i renamed firmware.bin file, i removed secure hardware usb, I put sd in mks and connected usb cable, led D3 and D2 start flashing slowly and then loudly, then a white window opens where I see firmware.bin file, where am I wrong?
PS:i only connected mks sbase with usb, no motors, no power supply
EDIT:finally i managed to load grbl-lpc, i changed sd, formatted in FAT32, $ 140 and $ 141 is right 0.6A for k40 motors? does it seem a little 0.6 amps?
