Hi all. I’m trying to give GRBL-LPC a try since I’m hearing good things. I keep getting the “No supported firmware detected. Closing port COM6” message from Laserweb v.4.0.988
I’m trying to use the firmware.bin from: https://github.com/cprezzi/grbl-LPC/releases
I’m running windows 7, so I had to install drivers manually. I found the driver in the GRBL-LPC source code and now my computer recognizes the Smoothieboard and assigns it to a COM port while on the GRBL-LPC firmware. Laserweb sees the COM port, but I get the error every time I try to connect.
I’ve had this all working with smoothieboard firmware, but I wanted to try GRBL-LPC. Anyone have an idea what I’m doing wrong? Is there a driver setting that needs to be tweaked perhaps?
I’m using a 4x smoothieboard with a custom build co2 laser.
I had that same problem with one particular Win7 Desktop Dell PC. No matter what I did, I couldn’t get laserweb to connect to grbl-lpc. It worked fine previously with smoothieboard and will connect via serial terminal. Had no problem with two other Win7 laptops to connect to grbl-lpc. I even tried another USB card. Replaced USB drivers etc. It wasn’t until I upgraded to win10 on that desktop that it finally worked!!! Microsoft
Okay, Thanks for chiming in. I’m updating an old computer I’ve got lying around. I’m going to try it there. I was thinking of using it as a dedicated machine for the laser cutter anyway… I’ll let you know if I figure out another way to fix it.
Well, I’m pulling my hair out a bit now. Fresh Windows 10 install on a different computer. Same problem. Windows recognized the board right away and assigned it to COM3. PuTTY connects just fine. It lets me configure settings and all. Laserweb still says “No supported firmware” and disconnects after a few seconds. I’ve reflashed firmware several times now.
I’d think there was a problem with my smoothieboard if it wasn’t for the fact that PuTTY seems okay with it.
When I initially connect with PuTTY, it returns:
Grbl 1.1f [’$’ for help]
[MSG: ‘$H’ | ‘$X’ to unlock]
Not sure if it’s supposed to repeat like that.
I have one more laptop I can try to connect with, otherwise I may need to stick with the regular smoothieboard firmware.
If anyone has any ideas how I could troubleshoot this, please let me know!
Thanks for the help! This community has been immensely helpful!
Not entirely sure I understood your instructions, Claudio. I created a new text document in “user>AppData>Local>Programs>lw.comm-server”. I then added a line “RESET_ON_CONNECT=1” without the quotation marks, saved it as env.txt. Then I changed the file extension so I had the file env.env. Sadly, this did not appear to accomplish anything.
Thanks for taking the time to read my post and offer a suggestion.
I have tried connecting from 3 different computers now. All with the same result.
@Sam_Bakker There is something additional you can try:
If your board needs a bit longer than usual to respond at connect, you can add the line “GRBL_WAIT_TIME=5” to the .env file to increase the timeout to 5s (instead of 0.5-1s).
I gave that a try, and still no change. I’m still getting the same no supported firmware message…
PuTTY does seem to connect instantly when I connect there.
The installation path on my Windows 10 system is “C:\Users\username\AppData\Local\Programs\lw.comm-server”.
Did you just shorten it in your post or is it realy different on your system?
