GitHub reports an internal error when downloading firmware.bin; hopefully they’ll fix it soon.
Installing it is the same as upgrading smoothieware; place grbl’s firmware.bin on your sdcard. Make sure your PC has a working sdcard reader before doing this; grbl doesn’t forward the sdcard to the PC like smootheware does.
Piggybacking on this, same question. What is the current compiled configuration? For the C3D Mini we need 2.5 as the pwm pin. The stepper signal pins are same as smoothieboard.
pwm is at 2.4 in the firmware.bin I posted. To change pins or other non-$ settings you have to edit grbl/config.h and rebuild. It needs the arm-none-eabi-gcc toolchain, along with make.
Issue for me is i am not sure how to rebuild the file into a firmware.bin? I done a bit with my Um2 with the arduino software i think thats a hex file though?
@Todd_Fleming would you mind explaining a little for a noob?
@Bonne Wilce I hope someone will write up detailed build instructions for the various host OSes. If you’re familiar with building things on the command line, then see the build notes on the GH link you posted.
super @Todd_Fleming ill test this tomorrow, really need a fix for rastering so i hope Grbl can be the answer. What pin should the fire pin be on this set up?
I leave the pot in place and connect the power supply’s L input to the transistor output on 2.4; no level converter or resistors needed. This is with a K40.
