You measured:
From the P2.4+ to the VDD (+12 or +24VDC) and you got an open?
You may be missing a power jumper. But not to worry because I do not think you want this pin anyway.
The P2.4- may read open as hopefully it is the drain of a MOSFET.
Lets move on to the wiring:
FYI This supply looks like it has the same connections as yours?
Once wired I would leave the wire to P2.4- open and test the setup by grounding it.
With P at ground (enable switch and interlocks etc closed) the laser should fire when the wire on L is touched to ground.
@Chris_Menchions first lets take the board out of the circuit. With L on the LPS connector “DISCONNECTED” and everything else wired as my drawing shows does the laser fire all the time?
I have nothing going to T. Never did hook anything to that. Only terminals I touched were L, p, g, in, 5v.
I have a guy with similar machine and psu going to send me pics of his but where this is not going to be the same controller I dunno what good it will do.
