@X-WL1
You also need to replace this
In you declaration every variable linked to millis() like lastupdate … need to be of type uint32_t not int
Because after a while it will not work properly.
Have you tried with fastled.show() instead of fastledshowesp32();
@Yves_BAZIN Replacement for fastled.show () gave the result. 20 minutes without mistakes. However, there were still periodic blinking of one of the outputs. I’ll try to use your FastLED branch. How can I store multiple branches on my computer at the same time?
@X-WL1 let me guess the blinking is linked to the pin 3
You cannot have two branches at the same time.
To setup my branch it’s a bit more complex than sam’s one and as u use WiFi you would need a ‘dead’ pixel otherwise the first pixel of each row will blink.
If you want to try my branch I can do the programming setup.
@Yves_BAZIN Do you think this is connected with the answer to the series? now wait and try to change the way out. thanks) whil try on the current library.
