Hello, so im writing a program to automate making items with names on them, and im encountering a problem when trying to render the models with special characters ž đ š ć č, where it cant translate them i guess and it just ends up crashing. ill post the code here and explain a bit within it.
import pandas as pd
from solid import *
import subprocess
import time
def assembly(annotation1="", full_name="", annotation3=""):
# Load the STL file and add annotation
a = import_stl(f"C:\\Users\\Miki\\Desktop\\Blank Key Chain.stl") + rotate([-90, 0, 0])
# Rotate and move the first text with linear extrusion
rotated_text1 = rotate([-90, 0, 0])(
translate([2.5, 16.5, 3])(
linear_extrude(5)(
text(annotation1,
size=5.3,
font="helvetica",
halign="left",
valign="baseline")
# Rotate and move the second text with linear extrusion
rotated_text2 = rotate([-90, 0, 0])(
translate([9, 10, 3])(
linear_extrude(5)(
text(full_name,
size=5,
font="helvetica",
halign="left",
valign="baseline")
# Rotate and move the third text with linear extrusion
rotated_text3 = rotate([-90, 0, 0])(
translate([2.5, 3, 3])(
linear_extrude(5)(
text(annotation3,
size=5.3,
font="helvetica",
halign="left",
valign="baseline")
#print("test1")
# Subtract the rotated texts from the main object
value = a - rotated_text1 - rotated_text2 - rotated_text3
return value
if __name__ == '__main__':
# Read the Excel file
df = pd.read_excel(r"C:\Users\Miki\Desktop\data.xlsx" ,sheet_name='Sheet1')
#print(df.iterrows)
num_rows = len(df)
#print(df)
#print(df.shape)
# Iterate through each row of the Excel sheet
for index, row in df.iterrows():
# Read values from the first row and first three columns
annotation1 = row.iloc[2] #1st phone number
annotation2 = row.iloc[0] #Name
annotation3 = row.iloc[3] #2nd phone number
annotation4 = row.iloc[1] #Surname
full_name = f"{annotation2} {annotation4}"
#full_name = str(annotation2)+" "+str(annotation4)
#print(full_name)
#full_name = full_name.encode("utf-8").decode("utf-8")
#print(annotation1,annotation2,annotation3,annotation4)
# Generate the assembly
a = assembly(annotation1,str(full_name), annotation3)
# Output the SCAD file with dynamic name based on annotation1
scad_file = f"export_{annotation2}.scad"
scad_file_location = f"C:\\Users\\Miki\\Desktop\\SCADfiles"
scad_render_to_file(a, scad_file, include_orig_code=False)
#scad_file = f"export{annotation2}.scad"
#scad_file_path = rf"C:\Users\Miki\Desktop\SCADfiles\{scad_file}"
#with open(scad_file_path, 'w', encoding='utf-8') as f:
# f.write(scad_render_to_file(a, include_orig_code=False))
######### Problem ko hočem renderat file ne gre, ker ima "full_name" presledek in ga unicoda ne sprejme. help
#Problem when i want to render the file, it doesnt let me since the "full name" has restricted character "\t" and doesnt work then i guess xD
# Run OpenSCAD to export the STL file
stl_file = f"{annotation2}.stl"
command = f"openscad -o C:\\Users\\Miki\\Desktop\\STLfiles\\{stl_file} C:\\Users\\Miki\\Desktop\\SCADfiles\\{scad_file}"
subprocess.run(command, shell=True)
time.sleep(50)
print(full_name, "je opravljen.")
This here is the error given back, as you can see it crashes at scad_render_to_file where var a has a var within itself “full_name” that contains a special char.
Traceback (most recent call last):
File "c:\Users\Miki\Desktop\Model_cut_v3.py", line 87, in <module>
File "C:\Users\Miki\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\solid\solidpython.py", line 518, in scad_render_to_file
return _write_code_to_file(rendered_string, filepath, out_dir, include_orig_code)
File "C:\Users\Miki\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\solid\solidpython.py", line 562, in _write_code_to_file
out_path.write_text(rendered_string)
File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.12_3.12.752.0_x64__qbz5n2kfra8p0\Lib\pathlib.py", line 1048, in write_text
return f.write(data)
File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.12_3.12.752.0_x64__qbz5n2kfra8p0\Lib\encodings\cp1252.py", line 19, in encode
return codecs.charmap_encode(input,self.errors,encoding_table)[0]
UnicodeEncodeError: 'charmap' codec can't encode character '\u010d' in position 555: character maps to <undefined>
So i was wondering, how i can fix this. Is there maybe a way to decode it within OpenSCAD?, though i dont know if thats possible.
Well if anyone has any ideas how to fix this, i would really appriciate it.
