My annual cnc pattern making for the best holiday of the year. Of course porting them to 3d print models.
This model is in the printer now.
Slightly over a 13 hour print time on the P1P at ~8.5" tall. Printed in 4 parts and only the third from the bottom needed supports due to the protruding windows. The rest printed without supports.
Your projects are very haunting!
Third iteration. First two attempts were failures but third was the charm. Printed in two parts. The grass kept breaking off so took them off.
I wonder if you could print the blades of glass flat, bend them with heat, and glue them on? ![]()
You definitely could but it would probably be easier to model the grass blades with a gentle 45 degree bend and enough thickness so no supports would be required for printing.
These models were made for cnc patterns, but just ported to 3d prints for fun. So whatever I get is fine.
Printing some candlesticks now. ![]()
I assume you will arrange suitably creepy lighting for them!
Couldnt find led lights???
Lol. Just looked into what I had on hand in my crafts supplies.
