Worked surprisingly well. Did a fit test and found out I should have used the calipers on the hole in the pump rather than take the diameter of the rubber. I missed by ~1mm and the valve blows out of the end of the pump. Parameterized so will add 1mm to stem diameter and plug diameter.
