Dear all, I have a problem with my CorelLaser, when I click on open button to open files it doesn’t pop up a window where I select file, its the same with the import button. Does anyone know what can I do to fix this issue?
The solution for almost any CorelLaser problem that has been widely successful seems to be to install K40 Whisperer, Meerk40t, or both. K40 Whisperer has been around longer; Meerk40t is newer and has some additional abilities. Both are open source, and supported here in their respective categories.
Also recommend the open source software solution. That being said, what version of corel draw are you using?
Same answer for any Windows software, if restarting the machine doesn’t fix it then uninstall and reinstalling it normally will.
