Hi, i have an mks sbase 1.3 board and i need to control a Huanyang VFD spindle inverter.
Can anyone help me with the setup and wiring?
Firmware: smoothieware latest cnc
VFD: Vevor 1.5 KW
Thanks
VFD: Vevor 1.5 KW
Thanks
What’s your preferred mode of control? Last I played with it, Smoothieware supports PWM and modbus / RS-485 for Huanyang VFDs.
There’s a sample config with pins for spindles on Smoothieware here:
thanks, I’ll let you know
Hi @cilynx, are the connections correct?
is pwm_period = 50000 suitalble for yl620 400hz vfd?
# Analog spindle settings
spindle.enable true
spindle.type analog # [Default pwm] Analog can also be used for ESC spindles controlled by a PWM.
spindle.pwm_pin 2.3 # [Default nc] PWM output pin. Must be hardware PWM capable. (See http://smoothieware.org/pinout)
spindle.min_rpm 100 # [Default 100] Minimum RPM when spindle is on.
spindle.max_rpm 24000 # [Default 5000] Maximum RPM at 100% PWM.
spindle.pwm_period 50000 # [Default 1000] PWM period in microseconds.
spindle.switch_on_pin 2.6 # [Default nc] Optional output pin used to enable the VFD.
However I would prefer to just start/stop it without control the rpm because
i want to control rpm via VFD.
@mcdanlj it seems like you addressed the problem in this post but I can’t find the solution
I didn’t get it working, but didn’t try very hard either. I worked on other projects instead.
Looking at the yl620 docs you linked, the factory PWM frequency is 8kHz which would be 125 microseconds in the config. Your wiring looks reasonable.
