Which Co2 laser can be operated with Eleksmaker Mana SE? I wanted to operate more than 150w or 200w with it, can it be done technically?
there is something for the self-construction that can be controlled via grbl 1.1
I don’t know what the type of control board would have to do with the power of the laser.
If I were spending enough for a 150W or 200W laser, I would certainly not be choosing the controller by what is cheapest. Control boards are mostly interchangeable; what led you to this one in particular?
What are your goals?
all these systems are too expensive for me … but i need a strong laser from 150w and i want to use lightburnsoftware … i already work with a w20 laser
