The K40 Intro linked from the top bar talks about this a bit. Most CNC controller hardware can be used with a laser, and controllers that can run one of the open source firmwares that speak gcode are released faster than we could maintain a list… But the K40 Intro definitely lists several that are purpose-built for controlling lasers.
There’s more than one admin, but… @Tatarize who wrote Meerk40t has a video that explains the M2 nano in great detail. The M2 takes direct stepper commands. In 3D printing, Klipper has this kind of architecture, and now Marlin also has a direct step mode which can be driven by step-daemon.
Ruida controllers have a proprietary protocol that has been reverse-engineered (by, or partially by, @Tatarize as I understand?). Ruida controllers do not process gcode.
I think that “slave” is being over-used here, and would like to suggest that other terminology might be clearer.
M2 Nano has the computer sending direct motion controls to the stepper motor. It’s almost the same as old CNC designs that had the stepper driver controls wired directly to pins on the parallel port (remember those?) but connected via USB and using a very very simple protocol.
gcode is a much higher level language for describing movements. It is well over half a century old and is the industry standard for CNC motion control. A gcode interpreter has a lot of leeway to interpret the gcode in a way that matches machine constraints. For example, it might know the maximum acceleration the machine is capable; a machine might be stationary, then be given a command to move to a new location in two or three dimensions at maximum speed, and it might apply acceleration limits separately in each of three dimensions to make the move. Different implementations have different capabilities; for example, early 3D printers used firmware that didn’t implement the G2 and G3 arc commands because all the modeling tools broke shapes down to small straight segments anyway; recently, as fast 32-bit controllers with a lot of processing ability and memory have become common, controllers have implemented G2 and G3 arc commands and slicers have started to use them.
Mach 3 is control software that runs on a PC and expects to do direct stepper control. Mach 3 (and 4), as well as the nearly ubiquitous LinuxCNC, interpret gcode and send direct stepper control commands. In the early days this was typically done with the parallel port (see above) but now is often done via USB or ethernet. So this is conceptually similar to M2 Nano but utterly different in implementation and typical purpose. (These controllers are often used to drive industrial milling machines, for instance.)
grbl is canonical for grbl and was the origin of many open source firmware implementations; some were just porting it to new hardware, like @cprezzi’s grbl-lpc and Bart Dring’s Grbl_ESP32, and others have gone on to live a life of their own, like the Marlin firmware primarily used on 3D printers.
Relatively recently, grblHAL seems to be the “2.0” of grbl development that is unifying support for many hardware architectures in one source code base. This includes 16-bit and 32-bit architectures.
That’s a good start. There’s overlap; you can have a CNC controller with labeling covering use for laser and other domains.
It’s clear that Marlin development is primarily driven by 3D printing. That said, laser control is much simpler than 3D printing control.
32bit isn’t really a debate any more… ![]()
The TMC controllers have taken the world by storm, it is clear. The connection to 32-bit is tenuous, probably it’s just calculations to take advantage of 128-way microstepping… But that hardly matters because there is very little reason to get a 16-bit controller at this point. 32-bit controllers are cheap now.
“these drivers” meaning TMC? There are lots and lots of controllers, and at least many of the TMC chips can still be driven by step/dir/enable signals and were even produced to be pin-compatible with some prior chips, but they also enable a serial protocol connection that requires explicit firmware control, and plenty of firmware supports that.
