What would I have to do to be able to cut super thin aluminum cleanly? I want to cut some stuff out of the roll of flashing you can get at home stores which is 0.0084" or roughly 30-31 gauge ( https://www.lowes.com/pd/Amerimax-20-in-x-50-ft-Aluminum-Roll-Flashing/3010400 ).
I haven’t tried it yet but I don’t know if it’ll just fray as if you tried to cut aluminum foil with an x-acto knife.
I’ve considered putting something thin on top and bottom like a sandwich but I’m not sure if that’ll work or if it’ll add too much load to the cutter.
