What is the cooling type to this kind of machine?
How much is the thickness of the pieces?
Is there a difference in dealing with the types of metals?
III. Functions of GS-LFS3015 laser cutter
3.1. Equipped with exhaust device, have good exhausting effect and little pollution.
3.2. Small occupied area, high system integration, convenient to operate and maintenance, 24 hours continuous working.
3.3. The water chiller has good safety protection function, such as over temperature, lack phase, pressure, water-break, undervoltage, overload, etc. With stable performance, satisfied the cooling requirement of laser source.
IV. Specific configurations and pictures
4.1 Raycus Fiber Laser Source
We adopts the world’s highest level IPG fiber laser source, stable performance, assured safety of the whole product quality.
RAYCUS FIBER LASER SOURCE
4.2 Fscut Laser Cutting Head
Unique Fscut OEM laser cutting head with better compatibility with motion control card, software, auto-focus system. Thus there is seamless communication between these main control segment.
4.3 High Strength Whole Welding Cutting Bed
4.3.1 Our gantry-type flying optical path structure working table has been annealed to relieve internal stress strictly, thus significantly improves the rigidity and stability of the CNC laser cutter.
4.3.2 The working table have been handled with high temperature annealing and large CNC gantry milling machine precision processing, can maintain long-term stability and shock resistance, and ensure the precision of the CNC laser cutter.
4.3.3 One piece casting aerometal girder with light weight has good dynamic performance. Machining after tempering ensures the integrity, rigidity and stability of the girder.
4.3.4 Pneumatic cylinder, convenient to loading materials; pneumatic clamp, assure the located accuracy.
4.4 Automatic focus follow up system
1、Sampling rate 1000 times/sec, max following speed 500mm/sec
2、Height following control range 0-10mm
3、Statics inspection accuracy 0.001mm, dynamic responding accuracy 0.02mm
4、Support network communication and upgrade with flash disk
5、Support functions of oscilloscope, survey the electric capacity and height in real-time
6、Board touching alarm and board leakage alarm to prevent the cutting head in accident.
7、Edge inspection and automatic cutting, leapfrog cutting, hole punching separately, the lifting height can be adjustable according to customer
8、Positioning with just one key operation, fast and convenient
9、Compatible with any sort of cutting head and sprayer, electric capacity data is self-adjusted.
4.5 Oblique Gear
Using Taiwan YYC brand double driver gear and rack.
Accuracy standards: German standard more than six grade, Japanese standard more than two grade;
High precision pinion and rack to ensure the mechanical accuracy over the course of three meters in the scope of work.
4.6 Precision and Wear Resistance Screw Drive System
4.6.1 Smooth rolling, small friction coefficient, no empty rollingeven in micro feeding, realize nanometer located accuracy.
4.6.2 The frictional resistance of rolling is small, and the structure is simple, low abrasion of friction contact surface, thus realize the long time walking accuracy.
4.6.3 Optimal design of geometric mechanics structure, steel balls of 45° array, could not only bear the power of warp, anti-warp and cross directions at the same time, but also assure the walking accuracy.
4.6.4 Adopts special metals, wear resistant and high rigidity, integrated the advantages of other brand guide, more exquisite design, more flexible interchangeability.
4.7 CNC Control System.
4.7.1 Multiple-axis motion controller
Fscut multiple-axis motion controller is the most advanced capacitive DSP control system ;Fast processing path ;
Arc interpolation and regional interpolation is high precision Operation ability is powerful;Stable performance.
What is “this kind of machine” that you refer to?
