What I wanted was a slowly adjusting whole strip rainbow. There is still room for improvement but I thought I would show what I did
1 - So to begin with I wanted to light up a full strip with a single colour and then back down to black/empty, and repeat for the 3 colours (RGB): first code attempt - RGB rotations · GitHub
2 - I wanted to simplify it all. I knew that you can use the code ‘switch’ so I had a go and voila, a bit easier to see it all(code) and I could now do more colours
3 - final bit, messed around a little but realised I can now blend all the colours together by adding or subtracting the right colour. Also can adjust timings and light intensity
Hope it helps someone
feel free to use the code if you find it useful
