I have a Zebra printer that uses a serial cable. I am wanting to play with it with an Arduino. The cable averages $40.00. Since I only paid $5.00 for the printer and not sure what I will do with it, I decided to make my own. The connector is not standard and the closest one I think would work is $6.00 quantity one and would be gamble.
The first hurdle was finding pins that would work. I found a few connectors in my junk drawer that the pins fit. I removed the pins from the connectors and soldered them onto wires.
Use epoxy or acrylic for the body.
I had the same problem with the slide projector project but gave up and solved it another way (wired in directly).
Your clever use of tape to close off the connectors bottom and space the pins is brilliant.
Thanks; This will go into my arsenal of DIY hacks…
