Well finally finished the build and it seems quite solid.
The the test drive. great fun for about 3 mins that the wheel stop moving when the motor is still turning.
you probably guess. the gears in the diffs are stripped. both the ABS and the Bridge Nylon.
what else can I print these in to stop this. Any ideas
Pretty slow I have the printed gears all ready but waiting on a metal set up ,and having some set backs due to not printing in the correct material, I’m going to try PC poly carbonate. See
how that does
