Want to learn CNC, Need a DIY CNC router where can I get in India or other cheap source?
If you want cnc machine, welcome contacting us. We are Shandong Chencan Machinery Incoporated Company with 16 years experience on cnc machine area.
If you are after cheap, there is an extremely cheap mill build on instructables. Pipe, plexiglass, roller bearings. You might/should be able to mill soft plastic/wood on it. You haven’t mentioned how you plan on driving it; Mach3, LinuxCNC, or some other software. I imagine some/most of the mill driving software can run some form of simulation mode without a physical machine to drive.
