@Walter_Hsiao , Your work is always so good. Love the updated compact Eustathios carriage:
Thanks Eric! I still need to add it to github and send in a pull request. I’ll do that soon.
Hmm I love the look of the flying extruder. Might have to give that a go.
I noticed you said you tried having an A-frame above the printer with the extruder mounted but still had bowden problems. I was thinking of trying a similar thing. How long was your bowden in this setup?
Thanks Alex! Can’t wait to get my hands on one!
@Ben_Delarre I think the tube was about a foot long. Here’s a couple of parts that may be useful if you have some extra extrusions for the A frame:
With the extruder mounted above, there were parts of the bed where the bend in the PTFE tube would swivel around 180°. I didn’t notice any issues from that, but I’m not sure how much testing of large prints I did back then. I also didn’t notice any obvious artifacts from the changing radius of the bend in the tube with that setup, though I never tested explicitly for it.
Thanks @Walter_Hsiao I was thinking of just using two pieces to make a right angle coming out the top, I have 3 metal right angle supports and two pieces of extrusion that would put the extruder about a foot above the gantry. I’ll probably give this a shot this weekend as I think its probably a step in the right direction over the massive bowden tube I have now. Though I guess cable management for the hot end might be more tricky than with an a-frame?
I like the fans placed on top !, would this thingifile also work on my single Hotend Herculien ? (but keeping my 650 mm bowden-tupe)
@Ben_Delarre For the hotend wiring, I originally installed it with a cable chain, separate from the bowden tube, and left it like that even though the flying extruder arm would be a perfect place to run the hotend wiring (too lazy to redo the wiring).
@Jo_Miller This carriage should fit on the Herculien (I think they use the same cross rod spacing and the 8 and 10mm self aligning bushings mount in the same holes). The nozzle is significantly higher though, so I don’t know if the bed will reach the nozzle on the Herculien without other changes. I don’t think it reaches with the normal Eustathios Spider v2 build.
thanks Walter, I will give it a try in solidworks first,
@Walter_Hsiao I am so glad you also post STEP files, I was able to model a spacer that went under your duct for the E3D Volcano. It was a perfect fit.
Took me a bit to figure out how to make the pull request, but it is there now. It is just the spacer and nothing else. included multiple 3D model formats as well as the STL.
Just as an FYI, I did not use this myself, I actually combined it into one piece with the duct section and printed it as a single piece.
@Bud_Hammerton thanks, I love that people are using the github for archiving these mods and collaborations. I think it will help long term so all these great additions don’t get lost in the G+ streams.
Thanks Bud! Good to hear the step files were useful. I’ll have to try out the spacer, I was planning on making a volcano duct, but have never gotten around to it.
Spacer adds 11 mm depth per E3D’s specs. You can always scale in the Z axis of needed.
Made one. Had to order some magnets as I only had 10 mm round on hand.
Cool! Looks great, hope it works well for you. Thanks for sharing the picture
I’d like to give a try to the carriage but can’t print ABS (no heatbed).
I managed to print the duct in tglase but the block is another story.
Assuming PLA won’t hold the heat of the heatbed and the extruder. any recommandation ? XT ?
I don’t have much experience printing without a heated bed, but some brands of PETG seems to warp more than others for me. I haven’t used XT, and haven’t had problems with tglase warping, but I’ve seen it happen on a friends printer. For the block, I’ve printed it in PETG from Atomic, 3D Supply Source, and Sainsmart, but always with a heated bed.
Plastics with fillers usually have lower shrink rates than the unfilled versions so maybe Colorfabb CF-XT or 3DXTech Glass Fiber PETG could work? I don’t know. Another option is to just print it in PLA, it will probably work for weeks, maybe months, long enough to print a block on the new printer. If you do that, you’ll probably want to make sure the bushings aren’t too tight since you’ll need get them back out.
