I have not been able to get past jogging the spindle around. Cant find anything. Am I looking in the wrong place on Vevor. Any halp is appreciated.
First of all, wecome to the forum.
I don’t know which controller software your machine is equipped with.
If it is based on GRBL, you can start GrblGru and open the two controller windows.
Then select the port to which your machine is connected and select “GRBL” as the controller. Please take a screenshot of this. It should look similar to the picture below.
Thank you so much for reaching out. It came with Candle. I am actually setting it up again at my new shop. Just want to get it up and running before building the enclosure. Funny enough. I have actually built a coupler cnc routers in the passed. But for some reason I am just having a pain in the neck trying to get this thing running. This will be my first attempt in about 5 months. I just had to step away and focus on other parts of my shop. Any help would be appreciated. Thanks again.
