@Alex_Krause Cool. There is still an issue with the speed. It looks like the queue buffer machanism for TinyG is not correctly working yet, but I will look into that.
TinyG does not have a “Laser Mode” yet, so movement stops on each S-value change, which basically makes it non usable for raster engraving, but should be ok for cnc-milling.
Which stepper output does the rotary A axis default to? I have a rotary for my mill but I think it’s too tall to fit but I can rig something up pretty fast to test this.
@Jim_Fong you need to config stepper PIN, DIR, etc to that driver, so its recognized as an A axis. You keep Saying as is an user other driver for A. Does it make sense?
@Ariel_Yahni_UniKpty I’m pretty sure I configured step/dir correct for that driver. Need someone to look at the config.txt to see if I missed something.
@cprezzi I sent you a hangouts message with a few of my findings… Figure I would talk to you so I can get the issues posted in the correct sections of git
