Vector engrave: plugin for inkscape to create filled hatch. http://wiki.evilmadscientist.com/Hatch_fill
If you have an alternate solution please post it.
I don’t use Inkscape, but I’m curious does this plugin allow you to adjust the spacing between the lines?
Vectric software has this feature and it works pretty well you can adjust your hatch… down side is its not open source
