Using the latest edge firmware-cnc.bin the board hangs whenever I try to home ($H). Using the normal firmware.bin works ok for homing (G28). Any ideas?
+Peter van der Walt every time I issue G28.2 or $H which should do the same the board freezes instantly. No movement at all. The config works for normal firmware so endstops should be configured ok.
Only xy. Z disabled. Leds stop blinking, that’s why I said it hangs
