I can’t see the version of UGS you are using, but I suspect that you have encountered the bug that I introduced when I upgraded to a newer Java version.
I will wait for next release (I can still manually send the gcode sentence !)
Thanks for this great software.
I have tested a lot and hesitated with gsender to finally stay with UGS which much better for continuous jogging mode!
