Trying to use this with my ramps 1.4 it says connected but nothing on the printer will respond to the app commands?
could you send me the console output please ? Please enable debug logging and reconnect + retry first. Thanks
its says connected even when I have it unplugged?
that is when I have it set to dummy mode. when I set it to usb-1 says not connected?
Dummy mode is just for testing. You need to choose usb-otg mode.
Please send me the console output (long press on console - send support email)
What error msg do you see when pressing the connect button ?
HI says no USB device found
I have tried all of the baud rates and they all do the same no usb found
ok will do thanks
Hi I have a usb female to female adapter. It all plugs in ok but do I need a otg adapter instead?
yes, you need a USB-OTG adapter. A simple Female/Female will not work.
Oh ok. that must be the problem. Thank you
