trying to use Cloud9 with BBB and get Error: Cannot find module ‘bonescript’ Any Idea whay may be causeing it?
Care to share your code? Are you using the stock Debian or Angstrom image? What does your NODE_PATH environment variable have in it?
Its the standard blinky one I am just trying to get started. I am using the standard Angstom. NODE_PATH ??? where is that?
var b = require(‘bonescript’);
var state = b.LOW;
b.pinMode(“USR0”, b.OUTPUT);
b.pinMode(“USR1”, b.OUTPUT);
b.pinMode(“USR2”, b.OUTPUT);
b.pinMode(“USR3”, b.OUTPUT);
setInterval(toggle, 1000);
function toggle() {
if(state == b.LOW) state = b.HIGH;
else state = b.LOW;
b.digitalWrite(“USR3”, state);
I used the link setup for cloud9 and with the way that setup runs I can’t put in the :3000.
