Trying to set a starting line code position in Chillipeppr w/TinyG and not having much success.
I have a project running with 73000 lines and the whole process simply stopped at 62000 lines and I can’t seem to get things restarted near that point. I use the GCode window to jump to a specific line but can’t get a proper response. As soon as I set a line number JSON disconnects. I reconnect but the system is now frozen and I can’t get any meaningful response.
I have tried from power up scratch. Homed and set my G54 work position. Loaded my tap file. Specified the start line. At that point JSON disconnects. The 3D viewer does not show the bit at the correct location and is stuck at the beginning of the file.
What are the steps necessary to restart a file from a specific line number?
Thanks.
