After switching to a new PC (Windows 8.1 Pro x64), I have trouble to connect to the SmoothieBoard via Pronterface/Repetier Host.
When I plugged in the Smoothieboard for the first time it automatically installed the sd-card drivers and I have no problem accessing it, also when installing the SmoothieBoard drivers itself there was no problem.
Then I opened up Repetier Host and connected to the printer, but it keeps saying “# Command Waiting” and that number adds up when I send a command. With PronterFace I get the following error: “[Error 31] A device attached to the system is not functioning”.
I already removed (reboot PC) and reinstalled the drivers (first 1.0 and second 1.1), but at most I can send 1 command (like HOME) and then it stops responding. Also updated the firmware on the board itself, but no improvements.
Tried 3 differend USB cables & other USB ports.
I also have tried it on 2 other pc’s (also with Windows 8.1 Pro x64) and with those pc’s it works flawlessly.
i had the same troubles wih my laptop win 8.1. to solve it, I disabled the SD drive in the periphical system management (Mbed.org MBED USB DISK USB Device) .
I can print now
