That’s how the page looks in my browser:
I’ve noticed, that I also get some errors on the browser console:
Maybe they’re related to the problem?
PS. Sorry for posting 3 times - it’s not possible to put 3 images into one post for newbies
Unfortunately I’m limited to my home office and don’t have access to my development environment.
Thanks for the fast reply! It’s not urgent. I was just playing around with LW4 and a portable China laser for our FabLab.
Sorry to bump an older discussion, but I’ve been looking into this too. It is happening to me when I use any Chrome v85; but a old chromium v73 install (chromium is the community port of Chrome) install still functions properly and the tools+macros can be selected.
I’d also noted that the ‘Camera’ selection entry (right before ‘Macros’) was also misbehaving; adding a known good url failed, the devices list was unpopulated.
Comparing the console of the two confirmed to me that the issue is actually happening in the Camera menu section, and the tools and macros are affected simply because they are processed after that. In the console log I see:
Uncaught TypeError: Cannot read property 'enumerateDevices' of undefined
at VideoCapture.getDevices (video-capture.js:194)
at VideoDeviceField.componentDidMount (webcam.js:28)
at ReactCompositeComponent.js:262
at measureLifeCyclePerf (ReactCompositeComponent.js:73)
at ReactCompositeComponent.js:261
at CallbackQueue.notifyAll (CallbackQueue.js:74)
at ReactReconcileTransaction.close (ReactReconcileTransaction.js:78)
at ReactReconcileTransaction.closeAll (Transaction.js:207)
at ReactReconcileTransaction.perform (Transaction.js:154)
at ReactUpdatesFlushTransaction.perform (Transaction.js:141)
I assume that this crashes out whatever script was supposed to populate the Tools and Macros panels before it gets to them.
And when I search on that it appears that trying to enumerate the camera devices when not on a secure or localhost connection is no longer possible. I find issues such as this:
To test this I set up a quick-n-dirty https proxy and accessed my install via that.
The Macros and Tools were back! Unfortunately I couldn’t get the server connection to pass through the proxy so I’m not sure how to work around in the long term.
I have a fully buildable from source LW4 and comm-server setup I can play with if anybody has any suggestions/modifications/patches that I could try. But this sort of Web/JS/Node debugging and fixing is way beyond my skills,
Alternatively; whet is the state of running LW through a secure proxy? Does anyone do it successfully? if so, how Could the comm-server do this natively?
This is a quick workaround you can apply via a browser flag. It restores the missing menu entries; but wont be available forever and results in a ‘you have messed with my security settings
’ nagbar.
Quick summary; Chrome is closing potential security holes, and LaserWeb is falling afoul of that when used in a client-server config. eg, you connect from a laptop to a remote Pi/Host plugged into the controllers USB.
To Workaround: Go to the following url:
chrome://flags/#unsafely-treat-insecure-origin-as-secure
And enable it; then enter in the box below it the full URL, including the http:// part and port number, that you use to connect to the Pi/Host.
Read and accept the warnings; And restart the browser via the big blue button.
What we are doing is allowing the LaserWeb site itself to be treated as ‘secure’, eg served via https, when in fact it is not. because we are restricting to this single internal site the actual actual risk this presents to us is trivial. If you cannot trust LaserWeb you should probably be uninstalling it right now.
When chrome starts there will always be a nagbar on the initial tab reminding you that you have this flag set, you can click it away but not disable it.
The Webcam preview, Macro
and Tool
menus should now be restored. If not; check you have the correct full URL and no typos in it. My server is accessed via http://10.0.0.110:8000/
So I saw:
And set the flag like this:
Resulting in Joy:
TL:DR summary; Chrome is closing potential security holes, and LaserWeb is falling afoul of that when used in a client-server config (eg, you connect from a laptop to a Pi/Host running next to the machine itself and plugged into the controllers USB.
In particular they have recently closed the ability to enumerate (list) the webcams on a browser unless you are on a secure connection. The Javascript encounters an error and exits. This can be worked around in code (I will have a go myself, it looks trivial) but until that lands there is a good alternative.
Finally: using Secure web hosting is not much of a solution since the insecure comms between LaserWeb and the comms server are now blocked as insecure comms from a secure client; resulting in a catch-22 when it comes to solving this via a secure proxy? Unless I am missing a config option to encrypt server connection too.
I wonder whether building LW into an Electron app would give easier control? Probably better than setting insecure configuration for system-wide Chrome in any case.
That is always an option, lots of LaserWeb users are doing that anyway (running it as a local app while plugged into the controller) and this issue does not affect them.
For those of us who want LW as a web service it will affect us, and electron is not part of the solution to that. The correct solution is adding logic in LaserWeb so that it does not enumerate cameras unless it is allowed to, this restores the current status-quo, at the expense of losing local cameras on the client machine.
Looking forward it would be nice to get LaserWeb able to serve itself securely without breaking the comm-server connection. We need to make the comms-server protocol able to work via https, and that will take Java skillz beyond mine.
Other issues, whether it is done natively, or via a lightweight local proxy (I favor the former) and handling self-signed certificates, etc. need resolving for this. But that is do-able.
The incredibly limited scope of the security exception is the only reason I would suggest it publicly in the first place. If you understand this, and still dont want the risk then wait for the code fix to arrive.
Not tested yet from chrome on windows; only from chromium + chrome on linux.
@mcdanlj The compiled installer of LaserWeb IS an Electron App, but we let it open for the user to also use it from source with a browser instead. This is especially usefull for installing lw.comm-server on a network PC or Raspberry Pi and just using it from a different PC with a browser, so no installation is needed on the frontend PC.
Did you try to serve the webpack files from a separate webserver on the pi? Maybe there is a problem with your proxy provider, I don’t know what else could be the problem. You can also try to switch to another proxy provider. Personally, I am using this one http://crowproxies.com/ for my work, it’s a good one, didn’t have any issues so far. My friend had quite a similar problem like you and after he switched to another proxy everything was fine. It’s important to choose the one that will be able to scrap any type of data from sites or apps.
Returning to the K40 after a 12 month break and upgrading from Laserweb3, it seems this issue is resolved?
I’ve just installed the latest Laserweb4 on a Raspberry Pi and the Tools menu is accessible. I’m using Firefox as the browser.
