TL;DR Am having issues with my router “wandering” mid job. Possibly due to blunting 1/8’ single flute cutters?
I started cutting a largest job I’ve attempted so far this past weekend. The total cut time around 2 hours in 1/8’ single flute end mill at 770mm/min in 2 sheets of 15mm plywood, 1.5mm per pass (10 passes).
The first sheet of the job went fine, cutting good chips. The second sheet started fine, the first part cut the “chips” where getting stringy and I wasn’t sure if this was due to the end mill dulling, or poor quality of the plywood I’m using.
About half way into the second part, I came into the shop (after dropping some rubbish in the bin outside) to find the router had wandered and started cutting right through the middle of the job.
Following the cutting path back I could see this started as a small deviation that compounded until the cutter had enough force to wander completely off course, something I have had happen before, but I was blaming the cuts and machine setup. It’s always possible the material moved, but I had 4 screws holding it down, so I doubt that is the issue.
How long should a 1/8 inch HSS single flute last cutting ply?
Have I got incorrect settings somewhere?
Is there any trick to check if the end mill is dull? it “feels” sharp after cleaning it, but I’m no expert.
Should I be dipping my cutters in Methanol first? (or is that mostly for MDF?)
