gcodeprintr Tip of the day Adjust the print speed during print just by pressing the extrude/retract buttons. Extrude(+) button will increase the speed by 10%, Retract(-) button will decrease the speed by 10% .
This allows you to manually slow down critical areas and speed up when needed.
btw. next version of GCodePrintr will allow to configure the percent steps.
Can these icons change between the running ‘speed’ mode and the paused ‘extrude’ mode so it’s more obvious that is what happens?
