Time to order ballscrews for my Herculien build and recently saw a question related to one I had:
Are the ballscrews linked in the BOM already machined correctly or should I have them machined to the same spec as the leadscrews from misumi (part # Mtsbrw12-480-f10-v8-s26-q8) ? That is: 480mm overall length and 8mm wide shoulders at both ends, 10mm and 26mm respectively?
Maybe I’m not looking hard enough.
Also- should questions like this be posted under “Build Logs”?
Whichever location is fine to post the questions. The linked ballscrew should be machined. But it might be a good idea to confirm it with them over email just to be safe.
